Heeeey,
My car's got another problem (yawn!), the speedo has started sticking. Has happened twice now, both times when it's been hot and the car has been sat in full sun. It goes up slower than the actual increase in speed (according to GPS speedo) and won't go back down to 0. This is fixed by a tap to the speedo, although the innacuracy of the gauge lasts a bit longer. All is ok once everything's cooled down a bit.
I found a thread in the search where someone else mentioned that theirs did it in the heat too (can't find the thread again now :suspect: ). Is there a quick fix, and will it start getting more frequent? It's not the same as the other thread by "KatK11" who's speedo was getting stuck at a certain speed, this is that it's moving slowly and won't go back down to 0.
