starting problems!!!!
CMF_1300supers
Hello friends!
last few days i've been having some starting problems...
the starter engine turns a lot of times and the revs dont go upper than 2000rpm... and i'm forced to hit the gas to try wake my cg13de!!!
CMF_kneival
Should add they found it was a leaky injector...
CMF_nz_aj
Revs not going above 2000rpm sounds like a disconnected or dead MAF. Difficult starting could be the plug to the idle control disconnected. I can't recall if these might actually be the same plug, or wether there's two. Any how they're both in the same area.
