T
Tesla
On the old forums i made a thread just before it went tits up that was along the lines of the following so apologies if you have previously read the old one or contributed in it which i missed
My K10 sometimes has a problem with starting. It makes the sound that would occur if you just held the key on even after the engine had started. The screeching sound.
However, when the sound occurs it occurs straight away. i.e. turn key and then the screech, the engine does not even purr to start.
It doesnt happen all the time. Sometimes if it does happen then it can happen 3-4times in a row!
I have limited knowledge with cars and the K10 is the first one I have ever really looked at. I took the starter motor out and give it a clean over. It seemed in good condition and the flywheel teeth were not worn.
Someone has said to me that the solenoid is probably at fault, this is the bit "stuck" to the side of the starter isnt it?
Can I just replace the solenoid or should I find a whole new/breaker job starter. How much would a starter likely to cost?
Thanks in advance,
Chris
Thanks in advance,
Chris
