Hi.
i have a micra k 12 2003 (automatic)
the engine does not start.
the dashboard illuminates when i turn the key .. lights / hazards / horn / cd player are ok. but when i turn to start the engine nothing happens... battery is ok too . i had it checked by an electrician. he also checked the fuses etc. oh and by the way the car is on 'P' Parking gear but the 'P' does not light up in the dashboard.
the electrician tried to start the engine through other means than the start key. i don't know what he did under the hood but ignition was there and the engine started w/o any problem.
but it won't start with the key from inside the car..
secondly when i turn the ignition key .. when the dashboard illuminates there is a sound .. a little sound which seems to come from under the hood .. i don't know how to describe that sound .. don't know if its a warning sign i don't know.. the sound goes off when i turn the key to turn everything off.
i don't know if it has sthing to do with the central locking of the car .. cuz the central locking works fine from the key and the door panel. but before i encounter this problem, the central locking from the door panel wasn't working properly. did i disable something while playing with this switch button? i don't know.
please help and advise. thank you.
