With this Santa Pod apparoaching I've been flat out this week sorting out everything on the car.. I couldnt get anyone to sort my gearbox out in time, where I had taken it to said they had done what i needed but I would need to assemble it. It turned out they hadn't and I had to go back there today with the gearset and this time I did it myself using their tools (I dont have presses) I had to press off the old bearings and strip down the gear set and remove/replace all the gears and syncros and then reassemble it onto the ST layshaft, and press bearings back on. Then reassemble the box, and the selector mechanism amongst other things and now after a clutch change the box is back on the car..
Along with other things this is what I have started and need to get finished for the weekend..
Custom strut brace from cut/modified K11 item.* (+respray)
Intercooler cover modified to make room for strut brace* (+respray)
Done:
Clutch
Gearbox rebuild
Rad (respray)
Battery relocation to boot
Mirror (+spray)
Engine bay clean up
Treat tyres with 'Grip!' tyre softener. (http://www.griptyresoftener.com/)
Re-wire ignition system + fit MSD high current ignition coil (with evo ignition amp)
Strip out interiour,
Turbo cover plate
New front numberplate
Intercooler cover cut + spray
Strut brace modify + spray.
Not done:
Cold air intake (+spray)
Fit full throttle gear shift. (may still do sat morning..)
Spray supercharger bypass valves and brackets. (not enough time)
Spray water bottle bracket (not enough time)
clean inside and out of car.. (sat morning..)
+ a few other surprises... means I should in THEORY at least be looking at mid to high 13's if the car doesnt explode on the start line.....
I am going to SP this weekend quite simply to beat my old old times and increase the gap (as I like being competitive like that) on the other Micra powered Micras on in the world.. I hope to have some competition this year, so I hope to make a decent target for these other modified Micras to play against...
Pics and more info later..
Done:
Clutch
Gearbox rebuild
Rad (respray)
Mirror (+spray)
Engine bay clean up
Turbo cover plate
Not done:
