Do recall the GA16 fuel rail needs minor modification, the centre needs chopping and shortening.
not sure mate uuummm frrraaannkkk haha
is yours more than 78mm between cyl 1 and 2 then karl ?
do you mean on the s14 rail frank?
going by the injector tip they have a 97mm gap between each cylinder
if i use the cga setup is it worth me keeping the s14 stuff?
wanna sell the cga inlet and fuel rail mate? would also need the throttle body holes to fit the cg throttle body mate?
pleeasse
+1 frank
Do you not think DET injectors will be a bit overkill?
The SR20DE has two differnt fuel rails. The SR20 you find in the primera GT is top feed and the SR20 in the almera GTi is side feed.
I've seen Primera GT's with side feed injectors, the red ones, 260cc i think...
Was it a P11? P11 only came with lowport SR20DE's.
The P10 eGT and eZX on the other hand came with a highport SR20DE and had a red top rocker cover from the factory. And if franks correct (which im sure he will be) then they have different fuel rails compared with lowports.
So is there Any difference for us between lowport and high port?what to do.... What to do ...?
Damn you know your stuff for a 16 year old
So as per the link I posted above the guy said it was off an s13 sr20de, would that be a highport? Just trying to find out where the fuel rail came from so I can get searching
Must be side feed and be able to bolt bigger injectors into
It's amazing what happens when you're asleep.... So I should be on the look out for a high port sr20de fuel rail? And which models had the high port, top spec almeras..top spec primeras?
Ok cheers but maybe it's because I'm half asleep but could me a Karlj run lowport almera gti modded fuel rail and injectors
I was referring to sr20 s13's from link above, I sold my s13 to get another Micra
Cheers for your help again mate
