Sr20 engine swap
I have a 96 k11 1.0 which I will probably be breaking soon. I am thinking of an sr20 project for the shell. Are mounting points, driveshafts and gear linkages all the same? (straight swap) or will it need a lot of modification. Off not, what would be the maddest engine to use that is an easy swap?
U will need custom shafts, and mounts made up, and wiring, but engine does fit, and will need bigger brakes, fuel pump, suspensions, and more
Write your reply...
