with the alternator. loosen the two pivot bolts under the alternator, then working above the alternator loosen the locking bolt (14mm iirc, maybe 12mm) then tighten the bolt which points towards the block (10mm or 12mm), until the belt is at the required tension. then re-tighten the locking bolt and both pivot bolts. job done.
