A bit if a long shot but has anybody installed spot lights on their front bumper? I will attach a pic of a ford puma with the idea I had, would like to see them on a micra.
Tia
Tia
![346473c75181cb4ba7aa8d43852de874_uploadfromtaptalk.jpg](/proxy.php?image=http%3A%2F%2Fwww.micra.org.uk%2Fapp%2Fuploads%2F346473c75181cb4ba7aa8d43852de874_uploadfromtaptalk.jpg&hash=fc6986f539a048b563c591aedb775850)
Cool! Thanks so much! Also how do you have them wired up? Are they simple on/off switch or connected up to the dipped/main/high beam?I will get a pic of mine up soon.
So you've got the spots relayed to the altenator then to a switch on the dash so they're practically seperate from the main lights? Sorry for being a pain, never wired spots before so just looking for advice also lol. ThanksAll my lights are fully relayed, the normal micra lights are not wired up via relays, this causes a volt drop. I fully re-wired them, running direct from the alternator, and relays for each feed i.e. dip, main, lamp pod, corner pods / spotlights. The spots work via switch on the dash so I can have main beam and then choice if I want spots.
Right so I think I got it? Its connected to the main lights using the relay then? Or I could instead of connecting to main lights run that to an on/off switch?Hard to explain in words, this is a good diagram :-
