I am trying to remove a 98 k11 1.3 gearbox , but am struggling to split it from the engine.
I have as far as I can tell removed all the bolts holding the two together, that is from memory - the rear gearbox mounting plate, the front gearbox mounting plate, starter motor, two bolts on the top of the gearbox and both the stay bars. Despite this I am still struggling to split the two.
The engine is supported under the sump(the long steel pressing under the gearbox that supports the rear mount is still in place) and the gearbox supported under the drain plug. I have removed the left hand drive shaft, but the right drive shaft is still in place as I have read in here that is not required to remove it. I am assuming that it will just fall out as I pull the gearbox to the left, but I still wonder if it will be easy to replace it as I re-install the gearbox?
I am seeing a small gap between the two varying between 2-8mm at the front / top as I jiggle / lever the whole combo, but cannot seem to get it permanent or larger, or indeed anywhere else around the circumference of the join(given it is difficult to get a decent line of vision). Am I missing something and where do I go next?
I have looked the info on here and of course Haynes, but as his is my first attempt at removing a box, a silly mistake is quite possible even likely so advice is most welcome.
Thank you
Thank you
