hi ,
Have a 1.3 k11 1997, with cbr1000 itbs.
I will be using the cbr injectors .i have a walbro fuel pump and adjustable fuel regulator to help sort fueling.
I'm looking for advice on what I will need to get it running right . For instance:
-what distributor do you use if you use one?
- do you use a trigger wheel and sensor?
-what ecu do you use ?
What else do i need to get it running ? Or what have you done /used
