smidge
» CMF Memberfound this info while looking thru trademe... sorry if its old news just sounds like the guys done it before!!
"If you have a dead CVT & a 1.3L motor, they all die prematurely. I'd suggest you fit a manual gearbox (a friend of mine had one fitted by Eastern Autos). Use the RS5F31V viscous box & LHS inner CV out of a GA16DE powered N15 (or N14) Pulsar. Clutch pedal, gear shift & mounts can come from a 1L K11. CVT half shafts & CV's match the 31 box. GA engine has the same bell housing pattern as CG"
