side lights fuse keeps blowing
hi every one i have a super s and every time i try a new fuse and turn the lights on the fuse blows has anybody experienced this. i have disconected all the light clusters and front lights to eliminate them so its some wire along the way,
the dash light is on the same circuit so i presume this is in the same circuit
any advice cheers
try testing for continuity to earth on the sidelight wire with the fuse removed, if continuity is present you have a short to ground which you'll have to find
