Side feed injectors
Hi , found out I have sr20 side feed injectors rather than the top feed I wanted, can these be fitted to a k11 dizzy engine? Would I be able to modify sr20 rail to suit?
Would cutting the pipe and using rubber hose work or will I need metal unions to join together? Also will the Injectors fit into cg13 injector holes?
Like the part of the fuel rail that holds the injector doesn't fit into cg13 inlet manifold? Wouldn't it be quite hard to weld? What does he do to make them fit?
