The previous owner of my car had attached the right side-strip of the car on with double-sided sticky foam so i thought i'd leave it on until it inevitably starts hanging off, which happened today.
I've taken it off and the majority of the foam but i'm now left with stubborn bits and residue which i'm hoping some WD40 will remove.
What would be the best way to get it back on? Will it be ok to use a strong adhesive and if so will i need to sand the ares down first?
I can take a picture and put it up if it helps. Thanks
