Hey,
Some backstory on the issue;
-1998 1.0 K11 with 1.3camshafts
-Been running E85 for 1year
-Left car to sit 3 weeks
-Battery dead
-2x Injectors shorted by conversion box (due to low voltage starting maybe? got stuck somehow) [Infinite resistance]
I then replaced the broken injectors with 2 used ones. Started running normal petrol since the conversion box failed. Now my real issue begins. When cold the car starts perfectly. When warm it just floods itself, only way to start it is with the pedal to the floor, triggering clear flood mode. Injector resistance checks out evenly within 0.1 Ohms on all injectors.
Question 1. So what could cause flooding? Still faulty injectors? Broken injector driver channel on ECU causing it to inject when it shouldn't? Leaning towards fuel issue, since the normal ignition tuneup did nothing. Should I do the 15k Ohm temp resistor trick as a bandaid solution?
Question 2. If I replace the ECU, do I need to match the key somehow? Guessing I have the NATS2?
-Battery dead
