Hi all,
I've found a nice set of 14" Seat Arosa alloys on eBay & was wondering if anyone knows whether they'd fit my Micra without any problems?
The pcd (4 x 100) is the same but will there be any problems with the bore - which is, presumably, the big central hole in the wheel that allows access to the hub nut?
Also would there be any clearance issues with the tyres fitted (185/55 x 14) - according to the seller the tyres are past their best anyway so this last point may not be that much of a problem.
I know a lot of people recommend 15" alloys but I'd like to keep any mods I do nice, simple & as standard as possible (if that makes sense) - also fitting 14" alloys (I have 14" steels fitted at the moment) means that my speedo will still read correctly. I think these alloys along with a 35mm lowering job will look quite good.
Thanks for looking & I'll need an answer quick (don't mean to hassle anyone) as the auction finishes tonight !
Here's the auction :
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=120181700371&ssPageName=ADME:B:WNA:GB:1123
