Evenin all
I've taken the drive down home from Preston to Suffolk to see my folks, despite having a bit of a noisy micra at the moment...
Every now and then (not always) there is a bit of a noise from the front wheel area when applying the brakes, which sounds like metal on metal, almost like a scoring noise if that makes any sense.
The noise then sometimes continues once the brakes are off, then eases off after a couple of seconds... next time I put the brakes down it either happens or not, it's usually when slowing to a stop rather than when just slowing down
You will know from my previous posts I'm no mechanic! Any ideas what this is - is it dangerous to drive back tomorrow? Would you advise driving some of the way then calling the AA because a noise 'has just started happening'
There appears to be no loss of braking efficiency, and when the noise occurs after the brakes have been lifted the brakes don't feel as if they're still applied
Last time the car's been in is for MOT in March and there were no advisories
I haven't got a trolley jack only the tyre change jack so can't really get under to have a looksie at anything. Any ideas?
Cheers!
Jim
Cheers!
Jim
