Tom 1.0
*Warning* Lots of text *Warning*
with all the really horrible accidents happening to K11s at the moment, i was feeling rather paranoid,
personally after reading this :
Comments
The Micra was first tested by Euro NCAP in 1997 and there have not been any major changes to its safety design since then. It did not perform very well in the frontal impact test, picking up most of its score in the side impact test. Neither child restraint performed very well. Its pedestrian performance is poor but similar to most cars in this class.
Front impact
The driver’s airbag worked well in protecting the head. There was no passenger airbag, but in the event there was also no head contact with the facia. The driver’s door remained reasonably straight, but despite the side impact beam remaining intact it was not effective because its end was no longer bearing on the front screen pillar. The front seat belts were fitted with reel mounted pretensioners, which reduce the slack in the belt before the occupant is thrown forwards. However despite the pretensioners the drivers chest contacted the steering wheel, which is undesirable as it can cause serious injuries. There was a particularly aggressive structure close to the driver’s left knee which could cause severe injury. The passenger in our test was very well protected. Only a simple two point static belt was fitted in the centre rear seat, which can cause severe spinal and abdominal injuries.
Side impact
There was a head contact above the door window which is likely to cause injury. The loading on the chest was reduced by an interaction between the dummy and seat structure that could not occur with a human torso. The abdomen was struck by a rigid, protruding arm rest and the pelvis was contacted by a polyurethane block.
Child occupant
Both child restraints were forward facing and contained the dummies reasonably well but the 1½-year old’s restraint had bad points and was rated as poor. They both stopped the children’s heads moving too far forward in frontal impact. In side impact the 3-year-old’s head came outside the restraint. For the 1½-year old in the frontal impact the neck loading was very high and in the side impact the head was not contained within the seat and was subjected to a severe blow to the side of the head. The labelling was good being permanent on both the seats, but on the 3-year-old’s the belt guides were not shown as red. The seat belts were of a type that can be used to increase the security of fixing the child restraints; however they were not used in this mode as there was insufficient labelling to explain how they should be used.
Pedestrian
The protection offered to pedestrians was not good and similar to many cars of this class. Most of the front of the car was aggressive with the exception of one point on the bumper, but other than this most of the score came from soft spots on the bonnet and windscreen "
everybody has been really lucky, I never knew the NCAP rating was only 2 stars
i dont quite feel so confident in my lil micra now ( i do 300 motor way miles a week... )
Comments
Front impact
Side impact
Child occupant
Pedestrian
