Rough ride
Hi,
I just drove my wife's 56 reg Micra K12 (I think its a 1.4 petrol manual). But it seems to be experiencing a very rough ride, there is lots of vibration in the steering column and accelerator pedal at low speeds in particular.
Much more than normal, I noticed the issue straight away. I'm curious as to what the issue is? anyone else had a similar issue?
its seems to have happened only a few days ago, as previously it was fine. I've checked the tyre pressures and they are fine. Can't think what else to check. any suggestions welcome.
it could be a wheel bearing failing. one of mine started to go on a rear wheel.
Do the vibrations lessen/worsen if you swerve left-to-right as you drive?
