Rota Wheels
Hi guys.
I want to put some Rotas's on my Micra. I want to put the Rota Grid Concave. This are the measures of the wheel 15 x 7.0, 4 x 100, e20.
I used this site to calculate if the wheel will fit. But i don't know the suspension clearance or the scrub radius. I don't know for sure if the wheel will fit.
Does anyone put a wheel with this characteristics in the Micra?
Regaards.
Hi
I'm using AEZ 7x15 ,but dont know the et. Looks like around 30. The inner side shouldn't be a problem, as you see theres plenty of space inside arch... but if you have heavy dropped front there may be some rubbin' at fender
sam_3717-jpg.49895
here is 15 x 6.5J x ET40 with 195/50/15 lowered 50mm, front cambered 2deg, rear spaced 8mm
a 7" rim with ET20 may poke out beyond the standard arch
I think ET20 will poke a bit too. Can you recommend some sites where I can find some wheels? I found some sites already but I am struggling finding 13 or 14 size wheels.
Regards
