aren't all st rhd? oO do you mean lhd?
Would they not have different bulkheads? Or are they just blanked out?
why should they be different? I see no reason for a totally different one. I think you can easily modify the existing onethe bulkhead is different, you would have to take the one from an LHD k10 micra and weld it in.
you may have problems getting the master cylinder to fit,
I know, but where is the problem? I don't get it. If you already have a lhd micra to convert it, where is the problem? The brake master cylinder is just on a other place, just change it and bolt it on the place where it is on the lhd. use the lhd brakepipes and so on. I have a hole in my lhd bulkhead where the clutch cable and the speedo cable comes out on the rhd. so I think it should be the same with the rhd. it should have the mounting points and holes of both, lhd and rhd. rear brake lines have nothing to do with the bulkhead, fuel lines? why not keep them where they are? the engine is not turned 180° then same with the aircon... The only difficult thing is the steering rack!They are obviously different man. brake master cylinder, speedo and clutch cables come out on the drivers side on a rhd car and loom and aircon pipe work and fuel lines and rear brake lines and on the passo side they are completely different and would take someone who knows what they are doing to change all that around.
I would make it totally different... I would get a lhd micra in the same color, swap the bumpers and bonnet and then just put the engine with all bolt ons in and change the loom and the braking system/ suspension... This would be faster.
I think the problem is, you are also driving rhd cars, you have never seen a lhd bulkhead.
