CMF_spikem
» CMF MemberHi All, K11 2001.
Just replaced cam chains and tensioners now when the engine starts it seems ok then goes into a recurring cycle of revving up and down continously. Odd times it will settle down to a high rev idle or continue revving for a short while after taking the accel off.
I have read the other posts on resoldering the Tb,valve cleaning and checked for vacuum leaks but just wondered before I start on them if there is something obvious i could have missed re assembling the engine as it was running fine ( albeit noisy) before I stripped it down. . Engine timing is fine by the way and runs smooth No engine management light on
