Reverse Camera
  • Thread starter Deleted member 47850
  • Start date
D
Guest
I have a connect 2 head unit fitted in my 2016 micra, which does not have the camera button fitted, my question is can I fit a camera and input it into the head unit as I believe I can add a input into the connector, thanks
After carefully testing all the possibilities with an aftermarket camera and an OEM one. I can confirm that this head Unit in the EU without the camera bottom can not add a backup camera on it even if you have all the correct connections.
I will go with a screen that can be used for Android Auto and apple car play at the same time can connect with the backup camera.
