Rev counter
Red positive black negative. Probably pull them from radio. The green one is signal wire which depends on which micra you have. On the facelifts its a blue wire on the speedo clock plug
In my Haynes it was the blue one but theres also another diagram (I'm guessing for later models) which seems to suggest it would be a Blue/Yellow wire. There is also a Purple one which goes directly to the ECU, I don't know if you can use that one though.
I've only got one blue wire. I'll try the purple one. It's doing head in now. Just want to know what rpm I'm doing. Thank you for all the help.
I’m having the same issue here, tried the blue wire with black stripe, blue wire with green(or yellow) stripe and still doesn’t read the revs, don’t understand why it doesn’t work with the blue and black wite
I know
Its the BLUE/BLACK with GREY SPOTS on the wire.
At least for me it was
Edit: Wow 2015 dint notice that lol
Well that wire color is the signal wire for the k11 1.4 2002
