Rev counter
in brief your rev counter will probably have 4 wires? 1 is ground (more than likely black) 1 is positive, needs to be wired up to an ignition positive (more than likely red) 1 will be for the illumination (if it has it) this doesnt actually need to be wired but if you want to you have to pick up live when the lights are turned on, (the 1st 3 wires can all be picked up from behind the radio)
the final wire is the speed pickup, this needs to go the rev signal, now the easiest place to pick this up is from the dizzy, but it can also be found at the ecu sometimes.
what you need is the wiring diagram for the car and the one for the revcounter.
there's a thread on here that shows you how to do this
my counter had these wires:
red - ignition
black - ground
yellow - illumination ( i linked it to my headlights so the numbers come on in the dark)
green - dizzy
pretty much what superls said lol :p
