rev counter
don't know about that one specifically, but if they're all pretty much the same you'll have to splice 4 wires. there'll likely be an ignition live, an earth, lights and a feed from the coil. The first 3 can be scotch locked from inside the cabin somewhere (use a haynes manual if you have one) and for the last you will need a wire from the negative of the coil. This will probably have been covered somewhere before, and there'll be instructions with it.
Altogether I'd guess It'd be no more than an hour to wire it in if you know which wires you need to splice. not sure about mounting it, that would depend on where and how you want to do it.
