solarice
Hoping someones got an idea whats up...everything was fine before had and since installing everything back into the engine bay and starting the car the rev counter is bouncing about, jumping to 3k then back to 1k idling then repeats...had a search on here but havent found a similar thread.
It also seems late in responding to revving...did the haynes ecu check method and everythings coming back as fine. Checked all the wiring no obvious probs, the alternators currently off the car aswell...apart from that everythigns the same.
any ideas where the bad connection is ? probably somthing simple that ive overlooked.
Cheers,
Kris.
Cheers,
Kris.
