Just bought a 1988 K10 Automatic with 42k miles on the clock .
Has been sitting for the last 4-5 years but the seller did the bare minimum to get it through an MOT (welding, break lines, air filter). I bought it from them on ebay and I managed to drive it home (150 miles).
The Engine and transmission oil hasn’t been changed in 4-5 years so I think it could do with a fair bit of maintenance.
I’m a beginner at amateur mechanics (I know how to do an oil change and simple stuff) and here is a list of the jobs I’m going to try and undertake to bring it up to spec:
Phase 1
I have some questions and would greatly appreciate your input with these:
Phase 1
- Replace Engine Oil + Oil Filter
- Replace Fuel Filter
- Replace Transmission oil
- Replace Timing belt
- Replace Water Pump
- Replace Alternator belt
- Replace Coolant
- Replace Break fluid
- New tyres
- Fix minor body rust
- As the oil has not been changed in 4-5 years Should I do an engine flush with a solution or is this risky for the engine? If so does anyone recommend the best flush?
- Should I replace the timing belt tensioner with the belt or is it unnecessary?
- Do I need a specific tool for the timing belt? The Haynes Manuel mentions a ‘Cam socket Wrench’. I couldn’t find anything when I searched. Can I replace it with my standard socket set?
- Should I perform a flush of the Automatic Transmission fluid or is this risky? When I tested the dipstick it still has the pink look to it but also has black in it.
- Any other advice or input on things that I might not have considered is most appreciated.
