none of them it's for a K13quick question is this on a k11 or 12 ?
Extremely unlikely. Would also be expensive. Is there no centre console for a k11? If u must you could make a centre console with aluminium plate, snippers, a pop riveter, sponge and vynil. Really once all centre consoles were made that way particularly on expensive exotic low production cars. You can buy vynil car trim from Woolies.
Sent from BlackBerry 9790 using Tapatalk
Ps please keep this thread k13, you can discuss k11 on k11
just seeing if it would be possible, am fitting an almera gti one in mine,
and i'm still discussing the k13 in regards to fitment on the k11
Here are some measurements so you can approximately make an idea:Ive got the super s seats whicha re slimmer so might be possible ?
I think you would get more than 500ma if you connect something that does not use data but then as it seems its powered from the head unit if you pull too many amps might blow fuse in head unit. I've put a cigar lighter in the place where the usb went but not connected. Adrian?? pointer to fuse box inside the car is the right way. The link to micra k13 workshop manual posted here should contain all that's needed to find the best place to connect a live. To be honest was hoping someone else would get round to this before me.
For camping 12v to 240v converters are now very cheap and small. Its worth fitting a cigar lighter. PS When I looked at first Micra K13 in Derby at COOP dealer sales man said they had fitted a cigar lighter for one customer.
Tapatalk
Hi again!
I've just connected my lighter and I would like to share my experience.
First thing to do is to remove the upper box. Remove the 2 screws inside, then grab the box from inside, there where it swings (grab the black plastic, not the door, it may break).
Then remove the next 2 screws of the lower shelf, and again pull it out.
Remove the fuse cover, which is placed on the side of the console. Pull it out... might be hard at first time.
Remove the 2 screws that hold the fuse box and play the box's way out, there where the shelf should be, so you can have better access to the fuse box.
According to the manual, the lighter shares the same route with the acc fuse. When you turn the back of the fuse box, you can observe that from the blue relay leaves a copper plate. That plate feeds the 12V to the lighter and ACC(accessories). I've soldered my new wire directly to the copper plate. It is tricky to solder because of the plate's heat dissipation properties. Do not worry about the box's plastic, because it is heat resistant (tested it the hard way ).
Also between the fuse box and the lighter make sure to have a fuse. I had an old auto fan cable that had a small fuse box and I've used that one.
Here are some photos of the fuse box and some hints: Hope it helps... If you need any help, just reply to this one. I still have to mount a lighter on the second Micra that I own.
Hi Adrian,
I'm trying to access the fuse box for another mod I'm planning next week and found your post very helpful for pointing me in the right direction.
When removing the upper box, did it put up much of a fight to remove? After removing the two screws at the top inside the box, mine just won't budge. I'm worried about breaking it, but did put most of me weight behind pulling it. Maybe I just need someone with a few more muscles to pull it a bit harder, or maybe I've missed something here?
Rabbut
Hi there Rabbut!
I am happy that the post helped you! The upper box is hard to remove because the clips are new and they sit tight inside. There's no worry to break it, there are just 7-9 clips holding it in place. Remove the 2 screws inside the box, do not mind the 3rd one that holds the metal closing bracket, that can be removed after you pull out the box. Grab the box from the inner "ears" with both hands and pull it out. The red arrows in the following picture show where to grab the box. Grab the plastic of the box, not the door. It requires some strength. Also sit tight in the seat, as the box will loose it may pop and slap you in the face believe me you don't want that to happen.
Once you remove all the boxes, undo the fuse screws and remove the fuse box in front, in the place of the upper box. There's the only place you can work. If requires soldering, remove the relays in order not to damage them due to the iron heat. The fuse box do not come out much, so you'll have to work with the soldering iron inside, so be careful not to damage the plastics with the iron hot tip. I used heat shrinking tubes to isolate the soldered wires.
Best regards, A.
Hi there Rabbut!
Best regards, A.
The size of that glovebox is awful compared to the K12 one! I'm convinced I could hide a dead body in there!
Hi again!
First thing to do is to remove the upper box. Remove the 2 screws inside, then grab the box from inside, there where it swings (grab the black plastic, not the door, it may break)....
