Right to start i took the nearside wheel off and removed the split pin and bolt holding the wishbone on. Unbolted the drive shaft and left it in place.
I then jacked the car up so I could get right underneath. I started to unbolt the 7 or 8 bolts around the gearbox case (the ones that hold It to the engine.) and the shifter linkage once I had done this I put a jack under the g/b to hold it's weight so it wouldn't put strain on the engine.
I then drained all the oil out of the g/b and pulled the ns drive shaft off.
The g/b was now loose so I started to pull it off when it was pretty much off I removed the offside drive shaft and that was the lot
