Replacing Wing Mirror - Heated or Non Heated - 2008 Model?
Hi all, new here...
Sadly I am now missing the offside wing mirror off my 2008 16V Teckna K12 model and dont know if I need to buy an electric unit or electric and heated, or are they one and the same?
There's no button for electric heated mirrors in the car that I can see and I cant see any icons on the glass of the remaining passenger one. I dont have the drivers one as it was not in one piece!
I understand on some they might not be marked as such but come on when the rear demister is on. I ran the demister for 10 minutes ish and no water evaporated and mirror still felt cold.
Can anyone advise?
Thank you
This is the replacement I bought from a 2006 model will this be ok? Took back off to see
if any indication on heating or not but not sure.
not heated. 3 wires are motor drive for adjustment. plug should be grey and 6 pin which looks correct to me. :)
heating should have another 2 wires (perhaps 3 if it's got PID feedback and given it's a 6 wire connector 3 seems likely). not sure if the K12 ever came with heated mirrors, there is nothing in the service manual or wiring diagrams about heaters.
Fuse box I recall is an empty slot for heated mirror?
Don't think mine has heated mirrors installed.
Was this a blank spot for heated or does the Sport model have this equipped unsure.
If rear demister does activate it probably, fuse would need to be present.
Worth a check if you do have heated wing mirrors and want to use the function.
