Not as witty as some!
Turtle said:
haha excellent.
When it says piston ring set...... is that for 12 rings? or just 3?
Theres 3 rings on each cylinder right?
Good question I don't know, it says set but as you say is it that per piston or engine? - let us know, but £140 does sound expensive, be supprised if they sold any at that price!
Yes 3 rings per cylinder sound right, and the picture shows 3 rings but is for illustration only!
With regards to going to scrappy for head etc. Not a bad idea, but I reckon that your making more work for yourself!! Taking two heads off, putting one on or take one off, strip and build it with new stem seals, and put the head back on?
Took me 3.5 hours to change Timing belt the first time (Mums K10), and just over 2 hours the second time (My K10). Got another one to do soon (Brothers K10
and going for a record this time!) but may take the opportunity to change the head gasket as oil is finding its way into the water. And while the heads off change the valve stem seals…etc…etc… So I’ll let you know how long this takes if I get there first…I’ll take pics this time!
Oh I’d cut the timing belt on the one from the scrappy, then you ‘just’ need to get the head off. Maybe cut the exhaust downpipe too! Lift it off with both manifolds on. Should save a lot of time.
IMPORTANT
If you follow the Haynes manual for putting the timing belt back on, it say something like turn the cam (Upper one) 2 turns anticlockwise with the tensioner loose to allow it to correctly tension the belt. (Use a length of wood with two screws correctly spaced to turn the CAM Shaft).
Unfortunately it seems to fail so mention that YOU SHOULD DO THIS WITH THE SPARK PLUGS REMOVED, otherwise the compression in the cylinders causes the Crank Shaft (Lower one) to jump round and the tensioner flies off!! The belt may slip too!!!
If the Belt does slip, then slide it off. Rotate the crankshaft whichever direction takes it the shortest distance so the pointer is at either 3 o’clock or 9 o’clock. Now the pistons are all in a line in the centre of the cylinders (no chance of valves hitting pistons). Line up the CAM Timing Marks, then the Crank Timing mark (Shortest distance i.e quarter turn!) Belt on and try again.
Getting the Crankshaft pulley bolt undone is quite a challenge, post again if you get stuck with this….
Let us know about those piston ring sets.
Oh by the way, Some garages have a special tool that allows them to change the valve stem seals without having to remove the head, so is alot cheaper, Hours labour? They remove the plugs, and force compressed air into the cylinder they want to change the seals on, this pushes against the valves and piston, so the valve spring can be compressed and removed without the valve opening, stem oil seal changed and put back. Might be worth looking into?
Interesting...
