Replacement parts fitted: headlights and distributor
CMF_sotheby
Hi folks!
I recently fitted some new parts, and wanted to share my experiences. I swapped the headlights as the original units with plastic lenses were casting little, if any, light at night. The plastic lens had become too milky. I also replaced the distributor, as the original had a coil pack failure.
Headlights ~ $150 delivered
http://www.expresscarparts.com.au/products.aspx?makeid=14&modelid=286&year=1995
These were a great buy! Local, Australian distributor. Glass lenses. Once fitted with new bulbs as well (details below), I couldn't believe the difference!
Osram Nightbreaker H4 bulbs ~ $35 delivered from Ebay
I got them in from the UK. Australian street legal. Nice and powerful white light.
CAD brand distributor ~ $170 delivered from Ebay
http://www.ebay.com.au/itm/CAD-Qual...29?pt=LH_DefaultDomain_15&hash=item1c29cc1ea1
Another local Australian delivery. Chinese Automotive Distributors brand. Fired up first go. Works fine so far. 1 year warranty. The only comment I'll make is the configuration of attachment plugs is different to the original, so the CAS connection appears stretched. If it becomes an issue I can get an auto-electrician to make up a new cable.
O2 sensor ~ $70 delivered on Ebay.
http://www.ebay.com.au/itm/NEW-PEC-...a&pid=100005&rk=3&rkt=6&sd=131461169960&rt=nc
A plug and play unit, for a very good price. Local delivery.
Otherwise, the n-CVT has clocked up over 170,000km and is still chugging along nicely. I'll next look at replacing the carbon rods in the electro-mechanical clutch, to play things safe.
