Removing Sidelight Bulbs?
TriNode
I can't understand how to get the bulb out, I did the first headlight after tons of pulling, then found I should squeeze the sides of the plug to get it off the headlight... I got the plug off the sidelight no problem, but how do you get the bulb / holder out? does it twist, clip or what?
Sorry if it's a stupid question, just don't want to force it and break it.
Thanks,
Anthony
nevermind, the other one twisted, so took pliers to the first...
You need to unplug the wire going into the back of the headlight by sqeezing the plug either side.
Remove the rubber cover on the back of the headlight
undo the clip for the Main/Diped bulb and carefully remove the old bulb
unplug the wire for the Side light bulb and turn 1/4 turn to remove
Remove the old Sidelight bulb and insert the new one without touching the bulb glass (use a rag)
Replace the new Sidelight bulb with holder and plug back in (test it)
carefully insert the new Main/Dipped bulb without touching the bulb glass (you may have to rotate it as it only goes in one way.)
redo the clip to secure the bulb in place
Replace the rubber cover on the back of the headlight and plug it back in uintill it clicks. then test it and repeat for the other side.
