Removing Rear Seat ?
Hi,
I need to remove the rear lower bench seat (not split) from a 2000 Micra .
I have removed the folding upper part, and also removed the rear bolts but there seem to be some odd ushaped bars at the front that don't release when you pull upwards.
Is there a knack with these?
There a nightmare, i dont know if there is a way but ive always pulled really hard. Ive totally ruined my rear seat because it wouldnt come out
where the seat clips into the front of the bench the wee plastic bits if yo ustick a flat head in and wiggle it was the way that worked for me ha ha
3 clips along the front, I just tend to put a big flat blade screw driver in close to the clip and lever the seat up over..... does the trick.
