Craig Unofficial Member (Gold) Club Member Oct 13, 2008 #1 Anyone ever done this, the trim at the top of mine is come unstuck so I'm looking to rip it our and then silicone it back in place. Cheers
joesouthgate Super Moderator Moderator Club Member Oct 13, 2008 #2 the bit that hangs out can be removed and replace with silicon without removing the window.
NeX You're after my robot bee Club Member Oct 13, 2008 #3 Craig said: Anyone ever done this, the trim at the top of mine is come unstuck so I'm looking to rip it our and then silicone it back in place. Cheers Click to expand... won't work, i removed mine and it NEVER went back in, ended up fitting a new hatch in the end as the garage wanted £90 to refit it! its a very common fault with the micras
superls K10 Tuner Oct 13, 2008 #4 we did it on out primera, not a bad job, stick the glass back in with sikaflex as is far better than silicone
OP OP Craig Unofficial Member (Gold) Club Member Oct 14, 2008 #5 NeX said: won't work, i removed mine and it NEVER went back in, ended up fitting a new hatch in the end as the garage wanted £90 to refit it! its a very common fault with the micras Click to expand... Ah, no, I'm not looking to stick the rubber wiuth silicone, I'm looking to bond the rear screen back in with it (or Sikafresh as suggested above). I would imagine that the glass is probbly about 1/3rd the weight of the boot....
NeX You're after my robot bee Club Member Oct 14, 2008 #6 Craig said: Ah, no, I'm not looking to stick the rubber wiuth silicone, I'm looking to bond the rear screen back in with it (or Sikafresh as suggested above). I would imagine that the glass is probbly about 1/3rd the weight of the boot.... Click to expand... ah ok fair enough, if it was me i would get an autoglass place to do it, you don't want that thing falling out. i think they use some kind of thermal bonding stuff, it goes on hot.
