But, remove the bottom cubby hole plastic (2 screws at side), remove the two screws at the bottom of the centre console. Remove ash tray and unscrew 2 screws behind this. Remove two screws up above the existing radio.
Then pull carefully from the bottom, and the centre console should come away from the metal mounts, carefully pull at the top to unclip the console completely.
Disconnect the cig lighter wire and remove the whole console.
Then just unscrew the radio from the brackets (4 screws).
When I pulled out my radio/cassette on my K11, the wire for the ciggie lighter touched a bit of metal and sparked.
I thought nothing of it & put the dash back on but now the ciggie lighter dont work.
Ive checked the fuses & ive made sure that it is connected properly - wot cud it be.
