removing fuel
do you want to run the car with the return pipe off ? you usually have to remove the rubber pipe at the bottom of the filler neck and siphon it
Yes i want run car return pipe off ... Where is it located please?
t
most fuel pumps work on demand nowadays, so yours may not have a return pipe ?
the k11 (CG) return pipe exits the fuel reg on the end of the rail, is yours the CR engine ?
I don't think the pump will run unless the engine is turning. and to be draining fuel while standing next to a running engine, is probably not good. I would just undo the pipe and siphon the fuel out.
