Cheers guys, just went out to do it and two of the bolts have obviously been gone at before I got the car because there is no teeth left on them at all.. Just a circular hole :doh:.
Right Ive took out 1 bold on each edge, and 4 plastic ones from the front. But it still seems to be stuck fast :S.
Once you've take the bolts out, that's pretty much it. There may be some plastic clips along the bottom which attach the bumper to the car, but these can be easily taken off. Otherwise, it should come out fine. Give it a bit of a bang!
there may be another 2 10mm bolts on the side mate the facelift has 2 per side IIRC only the prefacelift has 1 per side (as the bumper is half the size)
if you pull the sides of the bumper they should come clear away from the wing if they dont youve missed some bolts once they are all out take out the indicators and unplug them, then give it a bloody hard pull and itll drop off
