Hi Guys,Have any of you tried the different ways of removing the cv joint axle nut as shown on youtube.? That is without the use of a impact wrench or any power tools. One idea is to use a trolly jack and a breaker bar+correct socket, so instead of using a extra tube for the leverage you use the trolly jack under the handle and jack it up making sure that you are undoing the nut & spray it with WD40 first + remove the split pin. The youtube show that this method is easier the trying to do it by hand & as I'm not a strong ? person I'll try this way. Yours peter0003
