Just had a thought,
could you reduce turbo lag by opening a solenoid valve at low revs and open throttle (when the air is being restricted by the turbo) which alloweds air to bypass the turbo, straight into the manifold.
I have an output on the Hawk that can be configuared by rpm, but i was thinking someone with electronics know how could make somthing that turned on/off at a certain rpm?
might be a silly idea but just thought i would share it
I think that the Omex600 has somthing like this, but i was thinking it might work for people who arnt using such an advanced ecu?
