recon 1.0L head & bits for sale
Hi guys, I've a reconditioned (new valves) 1.0L head for sale if anyone wants one.
Comes off a CG10DE coded 1.0L engine off a 2004 Nissan Micra new shape with only 32433 genuine miles on the clock.
I had this head reconditioned last year as it had dropped 4 valves.
It was only run for 20 or so miles after being fitted.
It was skimmed and the valves replaced with genuine ones and bedded in.
Total cost was £350.00
When it was put on the engine was found to have a knackered bottom end so was scrapped but I kept the head to possibly use again.
It is complete with both crankshafts (in good condiotion) , coil packs, rocker cover, bucket shims, gasket, all the nuts & bolts from inside the head.
One of the bolt holes will need an additional washer on the bolt as there is a bit of wear on the top of the bolt hole.
I'd like to get the £350 back I spent on the recon so make any offers as close as possible please.
you can text / phone me (at a reasonable time only please, 07771 661511)
Paul
not to put a damper on it but a complete engine would be around the same price and less than half the work to do so you may have it for a while .....
