mark,
i rebuilt that ma12 you bought off me in the red k10 that ran the 18.1 sec qtr mile.
i bought the whole engine from a scrappy for 50 quid, then stipped it down in its entirety and rebuilt it. there was not a bolt or seal in that engine i didnt replace or touch.
From what i remember :
head gasket set - about 40 quid (although i would buy from nissan as head gasket is very important!)
new bearing shells about 40 quid
new piston rings were about 20 quid
then theres all the tools you need - spring compressors, valve spring compressors, balljoint seperator and piston ring insertor tool.
i have an excellent condition ma12 head if your interested??
id say budget about 200 quid for the rebuild. well worth it though as you then have the tools for later use etc.
took me a couple of months on and off to strip and rebuild it, but i was only working on it now and again. VERY rewarding at a personal level as every time i turned the key i knew it was ME that made that - hope that makes sense!!
need any info - just ask.
Luke
