Maccy Young K11-er! Jul 19, 2010 #1 This has probably been covered before and I think is a common problem on the K11, but the rubber seal around the rear windscreen has come apart at the top in the middle. Can anybody suggest the best possible fix for it? Cheers
pollyp Club Member Jul 19, 2010 #2 i pulled mine off completely and sealed it with PU sealant. was a messy job though or you could put a dab of PU sealant under the split joint then keep em pressed on till the sealant has cured, holding it in.
frank Club Member Jul 19, 2010 #3 my misses,s had the same problem, so i f##ked it in the bin :wasntme: Attachments SDC10955.JPG 275.7 KB · Views: 430
OP OP Maccy Young K11-er! Jul 19, 2010 #4 So there's no sealant at all on yours frank? Also where did you get the spoiler? I think mine could do with one!
frank Club Member Jul 19, 2010 #5 Maccy said: So there's no sealant at all on yours frank? Also where did you get the spoiler? I think mine could do with one! Click to expand... no, the screens are bonded in, and the rubber is just a "finishing trim" and its just the factory facelift spoiler mate :grinning:
OP OP Maccy Young K11-er! Jul 19, 2010 #6 Ah ok, so I don't need to worry too much then! Mine didn't come with one, may try to source one though as it looks pretty cool!
O Ollyo89 Jul 20, 2010 #7 Maccy, I've got a spare facelift spoiler if you're interested. Came off my k11 when I put a super s spoiler on. PM me if you're interested. Olly
