So the rear washer jet on my 1994 micra doesnt work, it never has done since I got it.
To clarify, to turn it on, you do just twist the rear wiper switch towards you until it flicks back to the centre correct?
The front jets work fine. Aswell as both wipers on the front, and the wiper on the rear. The car was sitting for 3 years before I got it and the front jets would shoot some brown sludge out when first used but they have since stopped doing this, presumably because all the crap in the lines has been cleared out from use.
I went out earlier and took the rear carpet up and took the clear rear washer line off from where it connects to the black line and still am letting it drain, alot of black sludge came out but the jet still didn't work. I don't think theres a bigger blockage inside since water is still coming out.
If I am not mistaken, both the front and rear jets use the same fuse so it wouldnt be that unless I am wrong, in which case, where and what fuse do I have to change? I can't seem to find it in any fuse box diagrams.
