Cheers, think I'll give Matt Humphris a try then![]()
Hi Tommi,
I run Matts rear tarmac springs (50mm lowering) & they do the job spot on, quite firm but sit well in corners, feel quite progressive when compressing. About £50 each IIRC
Skinner, what shocks are you using along with these springs?
Hi Tommi,
He skinner, sorry to bug ya, are you using the rear springs all the way round? :L if not what springs have you got on the front? :L
Not bugging at all fella, no there's a Tarmac lowering spring equivalent to go on the front mate. But I've just found that mine aren't compressed when the struts made up so I'm going to sort out if that's right or not. I've never had any problems with them and they handle great![]()
Yeh mate one of Matts![]()
Cool, ill be ordering up some springs soon then, pan hard rod deffo needed then?
Gonna be sweet need moar lows haha
Yeh anything lower than 35mm I'd start adjusting the axle shift mate, noddie on here makes cracking looking rods btw![]()
I've got mine on slightly uprated Bilsteins but they are very close to oe spec you shouldn't have any problems fella, helps the handling alotIIRC Skinner ran matts 60mm on stock shocks no problems, will need to get an adjustable panahrd rod from @Noddie though![]()
Is that standard length on the shocks Paul?I've got mine on slightly uprated Bilsteins but they are very close to oe spec you shouldn't have any problems fella, helps the handling alot
Yep standard length and diameter mate, been on over 4 years and no problems (touch wood)Is that standard length on the shocks Paul?
And springs are captive? You on -50mm or -60mm mate?Yep standard length and diameter mate, been on over 4 years and no problems (touch wood)
50 bud (though I thought they were 55's tbh) they are fully captive but I found the front coils when under no load can spin. This is sorted by putting a length of hose over the top and bottom coil it just adds enough tension that they couldn't spin if you got the front wheels in the airAnd springs are captive? You on -50mm or -60mm mate?
