Rear light cluster
they would only be legal if you but reflecters in the bumper aswell like on the listing pic, even then im not sure cause they dont say theyre e marked. also uve posted this in wrong secction should be in k11 not k10
thanks. so what do you guys think? would they look good? i wouldnt mind some, but if they would get me in trouble i dont know if i should
They will require having reflectors fitted somewhere on the rear of the car. Also you will need a seperate fog light installed. Luckily you do not require a reverse light for UK MOTs.
If I were you I would fit 2 circular lights in the rear bumper, 1 white, 1 red for reverse and fog.
If I had the money I would get them, but first things first I still need to fit Olly98 Cherry bomb to my car & a Air Intake.
But still you would need to wire in a fog lamp and reverse lamp as the original cluster has these already part of the wiring. "Easy Job"
