rear engine mount bush
hi,
this is my first post here but i've been on this site many times as a guest and normally find what i need through the search, but i cant find anything on this.
the car is a 1998 s-reg facelift 1.0 K11 Micra. Had the clutch changed yesterday and when i got it back there was a masive thud when you change gear and accelerate. had a look under the bonnet and the engine is actually rocking when changing and accelerating. took it back to the garage and they said there was a lot of wear in the rear engine mout bush. i've had a look around for it at most of the local jap car parts places and everyone has referred me to the main dealers who want £55+vat for this, which i think is quite expensive for just a bush.
is there anyone who would happen to have this bush out of the car and could possibly give me the dimensions of it with a picture so i can look up a poly bush equivalent?
i have a part number from the dealer of 1132099B15 - Insulator-engine mounting, rear
or no. 12 in this daigram - http://nissan4u.com/parts/micra/er_..._mechanical/engine_and_transmission_mounting/
thanks in advance for any help!
Should be able to get a used one from a scrappy for a fiver I'd have thought, or if you did want an uprated one you can get a nismo one for about £25 iirc
also bear in mind that although the rubber bush part # are the same, some mounts have different profiled metal casings so double check the replacements are exactly the same
