Rear Drum covers.
Littlewood
Here comes the BOOM!
Are proper seized on :O.
Tried hammer, bolts through the threaded holes, WD40 everywhere.
Still won't come off :S.
there is a little slot in the back of them that you can put a screw driver in to release the auto adjustment, its like a little wheel with teeth on, as the drums wear they make a lip , which is your problem.
You mean the little wheel to adjust the tension of the handbrake??
I got them off anyways, with good old mr. crowbar.
its a tiny little wheel that releases the handbrake auto adjustment, I grinded off the little lip on the drum in my k10 while they were off aswell.
